Hello Guest it is November 19, 2026, 03:36:43 PM
Author Topic: Set DROs from within G-code? I'm flummoxed.  (Read 9012 times)
« on: March 24, 2010, 10:29:03 AM »
Maybe the answer is obvious, but danged if I can figger it out.
From within g-code (NOT a vb script):  How do I set the DROs in Mach3, the same as if you'd clicked on them with the mouse and typed in a number by hand?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Set DROs from within G-code? I'm flummoxed.
« Reply #1 on: March 25, 2010, 04:47:48 AM »
You can set certain ones with a #number , for example you can set fixture offsets that will update there positions by setting the #2500,2501,2502, for XY&Z on G54.
To zero out the absolute figures you just do a G92 X0 Y0 Z0 or any combination of axis.
Graham
