G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: frogblender on March 24, 2010, 11:29:03 AM
Maybe the answer is obvious, but danged if I can figger it out.
From within g-code (NOT a vb script): How do I set the DROs in Mach3, the same as if you'd clicked on them with the mouse and typed in a number by hand?
You can set certain ones with a #number , for example you can set fixture offsets that will update there positions by setting the #2500,2501,2502, for XY&Z on G54.
To zero out the absolute figures you just do a G92 X0 Y0 Z0 or any combination of axis.
Graham
