Hello Guest it is November 13, 2026, 02:18:12 PM
Author Topic: Artsoft Mach3 Software OSAI 510i Controller Interface !  (Read 13926 times)
« on: March 19, 2010, 10:21:53 PM »
Dear General Mach3 Forum Members,
I am a new Mach3 Form Member, investigating all available options prior to committing to commencing any retrofit !
I currently have a old 3 Axis CNC Woodworking Machine that is running an OSAI 510i Controller which directly interfaces and controls all of the AC Servo Drives, Router Spindle, Drill Bank, & I/O's etc !
Can the Artsoft Mach3 Software be interfaced directly into this OSAI 510i controller, as a frontend ONLY interface ?
Has any other Mach3 Forum Member be successful, or has had any experience in trying to perform the above requested OSAI 510i Controller interface with Artsoft Mach3 Software as a frontend ONLY interface ?
Can the above request be accomplished with the use of any extra external hardware ?
Anxiously awaiting any General Mach3 Forum Member's responses and suggestions !
With kindest regards.
Kinetic Joinery Pty. Ltd.
Re: Artsoft Mach3 Software OSAI 510i Controller Interface !
« Reply #1 on: March 19, 2010, 10:31:03 PM »
You would need additional hardware, and some custom macro's to accomplish that. Not a trivial task. Independant control of the drilling spindles may be difficult as well.
There are two members here currently converting similar large machines. A Biesse and a Busselato.
« Reply #2 on: March 20, 2010, 03:38:10 AM »
What type of Osai drives does it have?
« Reply #3 on: March 22, 2010, 04:52:22 PM »
Sorry the OSAI 510i Controller is connected to YASKAWA AC Servo Drives and AC Motors ! Thank you !
« Reply #4 on: March 22, 2010, 05:03:19 PM »
You may be lucky in that a lot of Yaskawa drives can accept Step/Dir, do you have a model number for the drives?
