Hello Guest it is November 21, 2026, 02:22:21 AM
Author Topic: PCB Boards  (Read 8673 times)
PCB Boards
« on: March 18, 2010, 07:26:34 AM »
PCB`S is it possible to scan in a simple one sided board from black and white paper print out and with a suitable programme machine with mack3. I do not want to design the board in eagle etc.
                                               Hollydog
  •  9,378 9,378
Re: PCB Boards
« Reply #1 on: April 03, 2010, 05:25:31 AM »
Hi Hollydog,
Yes, it is pretty easy to do it this way provided you can accept 'isolation routing' for the finished PCB.
Rather than explain the whole process here, this is a link to the way I have done it  http://www.cooperman.talktalk.net/files/15.htm
If you need to remove all, or just some of the unwanted copper then a program such as CopperCAM could produce the toolpath but this route produces a large GCode file with even larger machining times involved.
Re: PCB Boards
« Reply #2 on: April 03, 2010, 06:51:49 AM »
Many thanks Tweakie best site I have  found  for a long time. I have built a Gantry machine working area 18" x 24" have it engraving and making cogs.
                   Many thanks for your help.
                       Hollydog.
