Hello
Guest
it is
November 21, 2026, 02:22:22 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
FAQs
PCB Boards
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: PCB Boards (Read 8674 times)
hollydog
15
PCB Boards
on:
March 18, 2010, 07:26:34 AM »
PCB`S is it possible to scan in a simple one sided board from black and white paper print out and with a suitable programme machine with mack3. I do not want to design the board in eagle etc.
Hollydog
Logged
Tweakie.CNC
9,378
Super Kitty
Re: PCB Boards
Reply #1 on:
April 03, 2010, 05:25:31 AM »
Hi Hollydog,
Yes, it is pretty easy to do it this way provided you can accept 'isolation routing' for the finished PCB.
Rather than explain the whole process here, this is a link to the way I have done it
http://www.cooperman.talktalk.net/files/15.htm
If you need to remove all, or just some of the unwanted copper then a program such as CopperCAM could produce the toolpath but this route produces a large GCode file with even larger machining times involved.
Logged
hollydog
15
Re: PCB Boards
Reply #2 on:
April 03, 2010, 06:51:49 AM »
Many thanks Tweakie best site I have found for a long time. I have built a Gantry machine working area 18" x 24" have it engraving and making cogs.
Many thanks for your help.
Hollydog.
Logged
Print
Pages:
1
Go Up
« previous
next »
