Hello Guest it is September 11, 2026, 03:06:50 PM
Author Topic: how to change the jog mode multi and step  (Read 22393 times)
« on: March 18, 2010, 03:21:56 AM »
when I start mach3 the job function is running perfectly I can change between the multi and step but when I load cnc file I can no longer change between the multi and step it is always in the step mode. What is wrong with this?
Re: how to change the jog mode multi and step
« Reply #1 on: March 18, 2010, 03:25:10 AM »
Are you meaning on the flyout screen? You should be able to change jog with code loaded.
« Reply #2 on: March 18, 2010, 03:38:18 AM »
Hi thanks for the reply,
when the code is loaded i can no longer change to multi it only sits at the step on the job window
« Reply #3 on: March 18, 2010, 03:42:12 AM »
Are you meaning with a MPG?  I think you only have the choice of continuous or Step if its keyboard jogging but with a MPG you have Velocity, Step and MultiStep options and all should be able to be changed when code is loaded.
Can you attach your xml please.
« Reply #4 on: March 18, 2010, 04:05:08 AM »
I can not select the continuous, it only sits at step in jog windows after I load the file
« Reply #5 on: March 18, 2010, 04:24:37 AM »
Please attach your xml as that is not normal.
« Reply #6 on: March 18, 2010, 06:06:17 AM »
here is my xml
« Reply #7 on: March 18, 2010, 06:58:11 AM »
Ok you have a non standard screen and I am guessing that may be the issue as I have just used your xml and changed screen so I can view. I loaded the standard 1024.set and loaded some code and I could change the Jog mode from Step to Continuous.
« Reply #8 on: March 18, 2010, 07:10:56 AM »
yes this only happends when I load certain file, not all file that I load do this. could it be only because of my certain file that I load into mach3?
« Reply #9 on: March 18, 2010, 07:14:41 AM »
Attach one of the files that cause the problem and I will see if I can find the problem.
