Hello Guest it is September 24, 2026, 04:02:21 PM
Author Topic: Changing image file  (Read 51461 times)
Re: Changing image file
« Reply #10 on: September 08, 2010, 02:58:11 PM »
Hi!
I would like that the Mach screens show me a picture, but the url of  is picture C:\Mach3\Bitmaps!
It is worst to me, i want change the folders, so i can open any picture from your computer.
for example: C:\Desktop\asd.jpg, or D:\Images\asd.jpg!
Can I change this url in the Mach Screen Editor?
Thank you very much!
Csaba!
« Reply #11 on: September 09, 2010, 02:47:27 AM »
Hello Csaba,
how are you trying to load the image? You can select an existing image, or add a new image.
When you select an existing image, the property dialog shows in the "Path" - line the relative path\filename. Doubleclick that path.
When you add a image, place the mouse pointer at the upper left required position and click left mouse button.
In both cases the dialog "Specify filename" opens. Within that dialog you can select the image. If you use default settings, the image must be lying in or underneath Mach3\Bitmaps. You can set the "root bitmap" in Options -> Settings Generic prog settings "User defined image path". In that case all images must be lying in or underneath that path.
I would suggest use default setting and copy the needed images into the Mach3\Bitmaps - path.
Klaus
« Last Edit: September 09, 2010, 02:49:12 AM by Klaus1311 »
The brain isn't a soap, it doesn't shrink when used.
« Reply #12 on: September 09, 2010, 04:09:36 AM »
Hi Klaus!
I will stick to the existing setup.
another question
because I change the pictures because this is a picture cut saws
how to do it no matter what the image name is always the one which they fill are in the folder. because they are always changing but there is only one
« Reply #13 on: September 09, 2010, 05:19:36 AM »
Hi Csaba,
I'm not sure I understand your question right. You can place an image with the same name as many times as you want.
Klaus
« Last Edit: September 09, 2010, 07:31:07 AM by Klaus1311 »
« Reply #14 on: September 12, 2010, 01:19:00 PM »
Hi Klaus!
I changed the image name, the folder is still standing but it is just a picture in the folder.
Be that, regardless of the name, load the picture in the folder.
regards Csaba
« Reply #15 on: September 13, 2010, 06:24:40 AM »
Hi Scaba,
what are you trying to do?
I've put a small movie on my site, In there i show
placing DRO's, button's and a bitmap
align DRO'S and buttons'
set text in buttons
set functions to the elements
change colors of DRO's
set skins to DRO's
place an image
change an image
perhaps this movie helps to solve your problem
Klaus
