Hello Guest it is November 13, 2026, 09:45:07 AM
Author Topic: Probing problem: "Probe ignore, activated at call for probe"  (Read 15196 times)
« on: March 13, 2010, 10:05:48 AM »
Tried the digitising wizard and when the program runs it moves the probe and stops when it hits the target, but instead of reversing, it just stops and after a while it displays "Probe ignore, activated at call for probe" and stops program execution. What are we doing wrong?
Anders G
Re: Probing problem: "Probe ignore, activated at call for probe"
« Reply #1 on: March 14, 2010, 10:52:33 AM »
OK. Figured out one bit. The scanning program scans "stich" fashion and the docs are slightly wrong, ie:
If the probe trips, the probe is retracted slightly from the trip point at the end of
command execution.
Well, it does not :) Now the probing program runs, but it only advances a few thou and then trips, without the probe tripping, so apparently does it trip on noise. Must put a scope on the input and look.
The probe is quite like this one:
http://www.vinland.com/Touch-Probe.html
And the breakout board is a:
http://pminmo.com/4axisopto/4axisDIYopto.htm
Probe connected to pin 11
« Last Edit: March 14, 2010, 10:55:35 AM by AndersG »
Anders G
