Hello Guest it is November 13, 2026, 09:44:09 AM
Author Topic: mach2 gcode thc300 problems  (Read 10907 times)
« on: October 01, 2006, 03:26:02 PM »
when i load the gcode in mach 2 thc3000 all i see is a bunch of circles.  if i dont not use a the thc files and just run regular mach2 mill or mach 3  i can see the tool path just fine is the a setting i have to adust or something this is really weird
John
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: mach2 gcode thc300 problems
« Reply #1 on: October 02, 2006, 12:28:32 AM »
it sound as is you have absolute I & J set when you should have it incremental, check this on the settings
Graham.
« Reply #2 on: October 02, 2006, 10:01:14 AM »
you are exactly right that fixed the problem thank you so much
John
