Hello Guest it is October 21, 2026, 03:09:06 AM
Author Topic: Using Mach3 on notebook  (Read 16127 times)
eagle550
« on: October 01, 2006, 09:25:39 AM »
Hi all,
I am using mach3 now, but I am wondering if it is possible if you can use mach 3 on a notebook and then a notebook without a parallel port. I readed in the mach3 manual that it was not possible to use mach3 with a USB - Parallel cable. But I found some other hardware what is not using the USB port but the PCMCIA card slot of the note book. I am wondering if some have any experience with something like this. Here is the link of the product I am talking about.
http://www.transdigital.net/info.htm
Greets,
Eagle550
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Using Mach3 on notebook
« Reply #1 on: October 02, 2006, 12:36:56 AM »
It sounds as if it will work but it would be a good idea to contact them and ask if its 3.3 or 5 volt output, 3.3 will cause you problems.
Graham.
Offline Greolt
  •  956 956
« Reply #2 on: October 02, 2006, 01:35:47 AM »
Eagle550
Look at the thread "Mach to DeskCNC"
If I am not mistaken (quite possible ;D)  this will be the end of the problem you have.
Mach running through a USB port, read modern Laptop.
Offline Raca
  •  10 10
« Reply #3 on: October 04, 2006, 09:21:05 AM »
Yes you can use traansdigital PCMCI card to parallel port and will work perfectly. I have notebook Toshiba portege 3480 CT ,600MHz and 192 Mb ram memory, and I had same problem . This solved it witheout any problems. If you have some more question please do not hesitate to contact me. Best regards Raca Sasa
eagle550
« Reply #4 on: October 08, 2006, 11:14:11 AM »
Well thank's for the answer (sorry for my late response). I ordered the card and I am looking forward to use it soon. I will let know if it works.
Eagle
« Reply #5 on: January 20, 2008, 03:26:26 AM »
Are you able to use the video plug ins ok?
I ask because I borrowed a 700MHz Compaq Armada M700 with Windows XP. It has a built in parallel port that works fine but jogging is crippled after I load a video plug in. So I am still looking for a suitable shop laptop for Mach3.
Tom Hubin
thubin@earthlink.net
