Hello Guest it is November 13, 2026, 09:36:22 AM
Author Topic: should I reinstall  (Read 28037 times)
should I reinstall
« on: March 04, 2010, 09:18:26 AM »
Hello
I'm having trouble with my G code display screen.  Although the Mach is going through each line of the G code, the display screen  is stopping in the middle and not showing that it is going through each line of G code. The problem is that about every 30 runs of the program, it is turning an output on at the wrong time resulting in my air cylinder getting smashed.  I have this Mach system set up to the same general configuration as another machine and I'm not experiencing this problem.  Is there something that maybe I do not have configured correctly?  Any help would be greatly appreciated.
thanks
josh
Re: should I reinstall
« Reply #1 on: March 04, 2010, 01:11:08 PM »
Cant think of anything it could be, maybe you could try lowering the lookahead to see if that helps.
Also have a look at CPU usage and see if thats abnormal.
« Reply #2 on: March 04, 2010, 01:27:25 PM »
I did change the lookahead from 20 to 1 and it still does the same thing?
« Reply #3 on: March 04, 2010, 04:01:30 PM »
What is the CPU usage like?
« Reply #4 on: March 04, 2010, 04:02:45 PM »
I dont know how to check,
« Reply #5 on: March 04, 2010, 04:04:15 PM »
If it would help I will go buy some more ram for it
« Reply #6 on: March 04, 2010, 04:04:48 PM »
Ctrl Alt Del all at the same time, will pop up the task manager and then go to performance tab.
« Reply #7 on: March 04, 2010, 04:05:05 PM »
What are the specs of the computer?
« Reply #8 on: March 04, 2010, 04:07:41 PM »
dell, intel pentium 4, windows xp, 20 gig hard drive, 750 megabite ram
« Reply #9 on: March 04, 2010, 04:09:12 PM »
handy trick, it hits 82%
