Hello Guest it is November 10, 2026, 05:19:50 AM
Author Topic: 'Verify' Function - Only able to check one axis  (Read 9609 times)
Offline rjb
  •  5 5
« on: February 27, 2010, 07:36:32 PM »
I've been trying to figure out how to use the verify button to perform a rehoming check on all three axes on my machine.  When I press the button all three axes move toward their home switches at the same time and when the first one hits its switch they all stop and return to zero position so only one is actually checked.  I don't have any problem with normal reference movement as the axis are referenced one at a time in sequence.  I would have thought the verify command would do the same ..is there any way to change this?
Richard.
Re: 'Verify' Function - Only able to check one axis
« Reply #1 on: February 27, 2010, 08:19:33 PM »
I think it will do all three axis if you have separate home switch inputs for each axis.
A work around posted a few days ago by RC was to have the axis you want to verify closest to a home switch, you can then move onto the next axis making it the closest and verify then the next axis etc.
