Hello Guest it is November 10, 2026, 01:56:57 AM
Author Topic: Mach 3 Turn Wizards  (Read 8644 times)
Mach 3 Turn Wizards
« on: February 22, 2010, 03:35:49 AM »
Just started using Mach3 on a CNC lathe. I am having problems when running G Code created using the lathe turning wizards. I have found that the M3 generated by the wizard does not activate the dwell I have set for the spindle and the spindle eventually stops during execution of the G Code. If I edit the M3 to M4 and save the G Code, eveything runs as expected.
Anyone experienced this or have any clues to what is going on.
Bazzag
Offline zarzul
  •  233 233
  • Wyoming, USA
Re: Mach 3 Turn Wizards
« Reply #1 on: March 02, 2010, 11:36:17 AM »
go into the configuration - ports & pins - spindle - change the m3 & m4 output#'s
or go to the outputs and change the pin numbers for outputs, usually #1 & #2  to correspond to your machine.
