Hello Guest it is November 04, 2026, 02:12:37 AM
Author Topic: Roadrunner.dxf?  (Read 19925 times)
Roadrunner.dxf?
« on: February 16, 2010, 11:16:49 PM »
Does anyone have the roadrunner in a .dxf format?
Re: Roadrunner.dxf?
« Reply #1 on: February 17, 2010, 01:32:17 PM »
Here's a couple files. TOONS.dxf has both Wile E. and a RR.   They are made up of mostly arcs.
RR.dxf is the original mach version of the RR converted using DXF to Gcode. You can find that here.... http://www.cnczone.com/modules/Downloads/userfile.php?id=22
You will have to clean out the rapid lines of the dxf produced, but it's still a great tool. Depending on your desired results, it might be a better idea to make a new RR file, as the one that comes with Mach is made of double lines, and all segmented. Not really the greatest quality code, but it's better than nothing.
