Hello
Guest
it is
November 13, 2026, 10:45:09 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
RC2.0c rewriting XML file
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: RC2.0c rewriting XML file (Read 14504 times)
chuckels
57
on:
September 26, 2006, 02:14:06 AM »
I just installed MACH 3 V RC2.0c and it over wrote my old mill XML file.
is there some reason this needs to happen? I had my old XML backed up can I use it with the new ver or do I have to re do all the settings?
chuck
Logged
Brian Barker
3,860
Re: RC2.0c rewriting XML file
Reply #1 on:
September 26, 2006, 05:53:56 AM »
It should not have done that
You should be able to use your old one
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
chuckels
57
Reply #2 on:
September 28, 2006, 12:27:35 PM »
Brian,
not really a problem but thought you might want to know.
since your not busy anyway. LOL
2.0d did the same thing. a message box pops up saying "custom setup mach3mill.xml copied to folder" but it is the default xml not the custom one created from the previous install.
chuck
Logged
jerinat
1
Reply #3 on:
December 31, 2006, 12:47:37 PM »
Mach3Mill.xml
Logged
chuckels
57
Reply #4 on:
December 31, 2006, 01:52:58 PM »
jerinat, what is your post supposed to mean???
the problem is that the Mach3Mill.xml is the default that mach writes when you install, not the old one that was customized before updating.
Logged
Brian Barker
3,860
Reply #5 on:
December 31, 2006, 10:02:19 PM »
The best thing you can do is to set up your own profile... that will make it so you never get your settings mucked up
Logged
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
