Hello
Guest
it is
November 13, 2026, 12:18:10 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
urgent need of help please..!
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: urgent need of help please..! (Read 15679 times)
gaz.
23
on:
February 10, 2010, 12:51:27 PM »
Hello,
I am in need of some help. I needed to purchase a new lead screw 500mm long, so i bought one and its the whong bloody tpi. I need an 11tip one and i bought a 9tpi one. I have searched all over google for one but to no avail.
I need this asap aswel because orders are backing up with no machine
. So anybody know where i can get one, it needs to be 11tpi and 12mm thick.
Thank you in advance!
u.k btw.
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: urgent need of help please..!
Reply #1 on:
February 10, 2010, 05:15:53 PM »
Why do you have to have a 11tpi, you can fit the 9 tpi and just change the 'steps per' in mach3 config and be up and running in no time.
Graham
Logged
gaz.
23
Reply #2 on:
February 10, 2010, 05:31:29 PM »
but i have all the nuts etc fit on the machine for the 11tpi and the other 2 axis are running on 11tpi. Could i just change the 1 axis to 9tpi and leave the others on 11?
If not where is the best place to get nuts, lead screws etc.
cheers
Logged
Graham Waterworth
2,785
Reply #3 on:
February 10, 2010, 05:36:34 PM »
Yes, just change the one, it makes no difference to the software, you just calibrate it as 9tpi for that axis.
Graham
Logged
gaz.
23
Reply #4 on:
February 10, 2010, 05:58:04 PM »
im abit lost on how to change the tpi settings, im on config> motor turning...no idea what to do now
Logged
Tweakie.CNC
9,377
Super Kitty
Reply #5 on:
February 11, 2010, 01:51:07 AM »
If you were to change one leadscrew from 11 pitch to 9 pitch then, what I would do is:-
In Motor Tuning take your existing 'Steps per' value (select the required axis first) and multiply it by 11. This would give you an arbitrary value which you then divide by 9 the result being the new value to use for 'Steps per'.
Logged
gaz.
23
Reply #6 on:
February 11, 2010, 12:40:07 PM »
Thankyou for all helping me, i really appreciate it.
Logged
Print
Pages:
1
Go Up
« previous
next »
