Hello Guest it is August 14, 2026, 06:57:07 PM
Author Topic: Pokeys with Mach Turn  (Read 28618 times)
Offline SScnc
  •  77 77
« on: February 10, 2010, 06:56:36 AM »
Hello, I have the pokeys plugin and software installed on my computer and I'm looking to use it with Mach Turn.
When I open turn, there is no plugin under the drop down menu for pokeys.
Now in the mach loader there is a profile for pokeys, but it comes up for the mill control.
Are these not compatible?
Thanks, Scott
Re: Pokeys with Mach Turn
« Reply #1 on: February 10, 2010, 12:52:56 PM »
reinstall mach3, I can see all the plugins under turn here.
OR, try uninstaling the reinstalling the plugin 1st mabey.
scott
Offline SScnc
  •  77 77
« Reply #2 on: February 12, 2010, 05:39:24 AM »
I tried both still nothing. I tried installing the plug-in for multiple pokey's and then just a for the single one. I still can't see it under the plugin menu.
Any suggestions?
Offline SScnc
  •  77 77
« Reply #3 on: February 12, 2010, 06:22:24 AM »
Ok I didn't have the plugin enabled under the config menu.
Now I'm having the issue of getting my MPG setup. Im using the 4axis mpg from CNC4PC.com. There instructions are very brief.
Any help is appreciated.
« Reply #4 on: February 12, 2010, 07:20:03 AM »
Use the tab key to bring out the screen MPG
You may have to enable the button for MPG  ;D
My own preference is to use step/velocity for getting close to the work. A fast wind of the MPG goes at rapid speed when in this mode  and then switch the mode to continuous jog for the final amount.
The step amount may not be accurate when using step/velocity
Then set a jog amount in the relevant DRO
Phil
Offline SScnc
  •  77 77
« Reply #5 on: February 12, 2010, 08:10:42 AM »
I wish it were that easy. Still nothing. I can't get the enable switch on the actual pendant to turn the LED on. Also how does mach know which button does what. Do I have to assign them pin numbers under ports and pins? Like I said the instructions pretty much suck on the website.
Offline SScnc
  •  77 77
« Reply #6 on: February 12, 2010, 08:13:15 AM »
Also I'm now getting the message "No Pokeys device found"
« Reply #7 on: February 12, 2010, 08:26:03 AM »
Well first you got to have the pokeys found.
I suggest you make sure you have the latest drivers current ver 2.0.13 of the pokeys
When it is enabled under CONFIG/PLUGINS
Then set it up from the menu PLUGIN CONTROL/POKEYS CFG
On that page it tells you how to set the pins
Phil
Offline SScnc
  •  77 77
« Reply #8 on: February 12, 2010, 11:51:02 AM »
Ok I'm making progress. I got mach to recongnize pokeys. Now, about the brains. I downloaded them and put them in the mach brains folder. I have three. Two are EStop and one is jogging. Do I enable all of them? I tried enabling the jog and one estop but for some reason I can get out of "Estop button pressed"
I have a jumper wire right now to simulate an estop button. Any ideas?
« Reply #9 on: February 19, 2010, 05:18:54 AM »
i am using the pokeys with turn. not using it with the plugin though. i found the mpg mode did not work satisfactory for me.but as a keyboard emulator its great. built a control panel with the functions of jog select , increment select,step, multistep,velocity step, select mpg, select axis, +- feedrate,+- spindle speed,reset feed, reset spindle, spindle on, coolant on.used momentary pushbuttons. created my own keyboard shortcuts for each function in screen4.also installed a 12 button keypad from velleman for future use.
