Hello Guest it is November 18, 2026, 05:14:33 PM
Author Topic: machine drags when backlash compensation turned on.  (Read 12899 times)
« on: February 07, 2010, 03:51:40 PM »
I just installed a new version of mach3 mill and my mill drags every time it reverses direction. I tried imputing different percentages of full speed but
didn't see much difference. Anyone have a solution for this.
Wawatobi
Re: machine drags when backlash compensation turned on.
« Reply #1 on: February 07, 2010, 04:21:00 PM »
I think it has to do with the shuttle accel, but I don't know where you need to set it. This might help.
http://www.youtube.com/user/hossmachine#p/u/80/A27nOkTFYDY
« Reply #2 on: February 07, 2010, 04:50:48 PM »
Good post Gerry....
 I use 50% and a shuttle of .005 and the backlash is rather hard, by that i mean almost instantaneous.
I suggest one play with the settings starting with 50% ( i don't like 100%, but that's my nickle on it ) and say shuttle of .5, then .05, then .005 to see the differences. Then up the % to say 75%, and again to 100% with the the different shuttles.
BTW, you may want to see the same affects when using exact stop and constant velocity. been a while since i played with the compensation.
« Reply #3 on: February 07, 2010, 04:55:55 PM »
