Hello
Guest
it is
November 13, 2026, 06:35:52 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
How to attach 24v relay to mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: How to attach 24v relay to mach3 (Read 12892 times)
omegasea21
22
on:
February 04, 2010, 03:18:20 PM »
Hello.
I have a breakout board and a modbus, how do I get mach 3 to activate a 24v relay? It just needs to turn on/turn off.
How do I attach the relay to the breakout board?
Logged
Carnoustie, Scotland
Re: How to attach 24v relay to mach3
Reply #1 on:
February 04, 2010, 05:08:09 PM »
Are you meaning your relay has a 24v coil? If so then best to get one with a 5v coil and use instead or you could get a 5v coil relay and switch the 24v coil with it.
There may be better ways to do it though.
Logged
Chestermarine
38
Reply #2 on:
February 04, 2010, 05:22:24 PM »
CNC4PC sells a board that takes 5v. ttl signal input, and will output a 24v. signal.
John
Logged
Tweakie.CNC
9,377
Super Kitty
Reply #3 on:
February 07, 2010, 05:38:12 AM »
This should do it.
Logged
Print
Pages:
1
Go Up
« previous
next »
