Hello Guest it is November 13, 2026, 09:59:05 AM
Author Topic: dro's no movint  (Read 96023 times)
Re: dro's no movint
« Reply #60 on: February 13, 2010, 11:46:13 AM »
How many microsteps? 200 X 10 TPI = 2000. 2000 X Micostep?=?
Re: dro's no movint
« Reply #61 on: February 13, 2010, 12:19:32 PM »
1000 but none of that matters yet. Nothing is going to happen until I get the pp working.
Re: dro's no movint
« Reply #62 on: February 13, 2010, 12:42:02 PM »
The pp port works. I can pulse the pins and they change.
NOW YOU SAY
IF WORKING:
So what is the voltage swing for pins 2,3,4,5,6 at the computers PP?
You may find that they are different but just list the high and low,please.
Then please confirm , via your drive manual the min pulse required and also the min volatge required.
Some other settings you need to change or try are in the pic.
Re: dro's no movint
« Reply #63 on: February 13, 2010, 01:22:55 PM »
0v-0v
Re: dro's no movint
« Reply #64 on: February 13, 2010, 02:02:41 PM »
I assume that you had Mach open and tried jogging the axis when you did that.
So, for PP port pin 2 & 3, take a voltage reading from pin 2 to ground and also pin 3 to ground ( not at the end of some cable but right at the pc connector), with Mach open. Watch for a change in voltage as you jog the X axis from one direction to the other.
Use the attached XML
« Last Edit: February 13, 2010, 02:09:21 PM by RICH »
Re: dro's no movint
« Reply #65 on: February 13, 2010, 02:15:03 PM »
I am sorry, use this xml as i have assigned the right and left arrow key for jogging the x axis.
Re: dro's no movint
« Reply #66 on: February 13, 2010, 02:23:13 PM »
No output. 0v on dir pin 3
Re: dro's no movint
« Reply #67 on: February 13, 2010, 03:28:34 PM »
You dont  have the port set on Ports and Pins, Motor Setup for either X Y or Z
Re: dro's no movint
« Reply #68 on: February 13, 2010, 04:27:30 PM »
Thanks Hood,
Make the following changes  and try measuring the voltage again.......
Re: dro's no movint
« Reply #69 on: February 13, 2010, 06:37:30 PM »
Rich, I hate to tell you this but that is the xml you sent. All I did was renamed it and saved it in Mach3. It did make a difference after I set the port to 1. The dir pins are now changing but no motor movement. I will check further tomorrow afternoon.
