Hello Guest it is September 05, 2026, 04:04:18 PM
Author Topic: Homing Limits  (Read 21733 times)
Offline NormB
  •  169 169
  • Norm
Homing Limits
« on: January 30, 2010, 08:29:34 AM »
I have hooked up my limit switches.  I am having a bit of trouble with the auto zero, All axis home correctly get the flashing yellow saying it's nto normal but anyway the auto zero is not working on the C & y axis???????
Re: Homing Limits
« Reply #1 on: January 30, 2010, 08:34:36 AM »
Are you looking at machine coords? Do you have AutoZero chosen in Homing and Limits? Do you have a Home Off value set, if you do your machine Coords DRO will show that.
Offline NormB
  •  169 169
  • Norm
Re: Homing Limits
« Reply #2 on: January 30, 2010, 08:40:58 AM »
I have not set Home off, yes the auto zero is checked for all three axis.  I keep getting amessage Axis are not refed to normal condition?  I am lost on that one
Offline NormB
  •  169 169
  • Norm
Re: Homing Limits
« Reply #3 on: January 30, 2010, 08:43:47 AM »
When I flip between Mach Coord and job I see the job in the middle of the table not at zero but I am at sero?
Re: Homing Limits
« Reply #4 on: January 30, 2010, 08:44:41 AM »
If you are talking about the Abnormal Condition just double click it and select OK, it is a real PITA as far as I am concerned as it warns you that you are not in your normal running condition but if you change something intentionally it will throw a warning and it gets people worried if they dont realise that is why.
Re: Homing Limits
« Reply #5 on: January 30, 2010, 08:45:40 AM »
The mach coords should be zero when you are at your home switches, your offset zero can be any place on the table you choose and have told it to be.
Offline NormB
  •  169 169
  • Norm
Re: Homing Limits
« Reply #6 on: January 30, 2010, 08:50:36 AM »
I have the offset to 0 0 0 XY&Z I double click on the yellow flasher and say it's okay but it keeps coming back.  Smnall problem, My part is in the middle of the table as far as Mach is concerned when I show the job it show the part as usual but when I flip to the other view I see the table and the job is nearly in the middle of the table not at 0?
Re: Homing Limits
« Reply #7 on: January 30, 2010, 09:00:56 AM »
Where is the zero point of your code in relation to the part?
Offline NormB
  •  169 169
  • Norm
Re: Homing Limits
« Reply #8 on: January 30, 2010, 12:00:19 PM »
0-0 on the machine is left corner ob boy front rear......... m*L*  Been there before My table is 25" wide and the gantry is 25" the Y axis is 39 inches long I home at the front corner x-Y on the left side of my machine.  My extream X is 25 and Y is 39 I hope this is clear........I found front and side make no sense I hope I gave you enough info.
Re: Homing Limits
« Reply #9 on: January 30, 2010, 12:04:20 PM »
What I am meaning is where is the X Y  zero in your code in relation to the actual cutting in the part.
