Hello Guest it is October 21, 2026, 04:41:31 PM
Author Topic: Ref All Axis Problem  (Read 11519 times)
« on: January 29, 2010, 02:51:07 PM »
I build new 3 Axis Milling router.
I put 3 home switch for 3 Axis. I check in Diagnostig page so it works well. But I press the ref all axis home, then Z axis dont move and DRO shows o.oooo
X and Y axis work. What is the problem ?
Please help.
Re: Ref All Axis Problem
« Reply #1 on: January 29, 2010, 02:57:43 PM »
Sounds like either you have not enabled them as Home switches in Ports and Pins or you have electrical noise.
« Reply #2 on: January 29, 2010, 03:10:34 PM »
all home sw are actif on setup
« Reply #3 on: January 29, 2010, 04:05:19 PM »
Then that only leaves noise as the culprit, unless your screen does not have the correct VB in the RefAll button. If you go to Operator menu then choose Edit Button Scripts you will see the Ref All button flash, click on it and see what is in the VB.
« Reply #4 on: January 29, 2010, 04:07:48 PM »
Could this be a problem with VB script on RefAll button.
Jeff
