Hello Guest it is November 26, 2026, 10:05:54 PM
Author Topic: KFlop/KAnalog  (Read 10345 times)
KFlop/KAnalog
« on: January 27, 2010, 04:04:00 AM »
Hi
I am trying to use Mach3 with the KFlop/ KAnalog boards, and I have my motors turning fine as expected, but for the life of me I can't get any of the inputs or outputs working.
 I am using V4.19 of the dynomotion plugin. And the latest lock-down version of mach3.
If I hook an input up to Mach3 ie input 1 and I configure this to bit 136 on the kanalog board, I can see the bit change on the kmotion software but on the mach3 end the input 1 led blinks continually whether the switch is made or not.  Does anyone have experience with this problem???   Do I need to add anthing special to my initalise script that is run on reset??
Any help would be greatly appreciated.
Regards
Andrew
