Hello Guest it is November 17, 2026, 02:12:01 AM
Author Topic: interrupts  (Read 10238 times)
Offline coop
  •  12 12
    • Signs of Mackinaw
interrupts
« on: January 24, 2010, 01:48:04 PM »
hey everyone,
i have been running mach 3 for several months now (mach 2 on another machine)
using a K2cnc, here is the problem...
i have run the same files many, many times perfectly, but every now and then , the machine gets a interrupt(stop)
in the middle of a cut, all the stops are very random and at different points,
everything is grounded well
i get them at diff. cutting speeds etc. i thought it might be a jarring motion setting off the limit switches but
i have run at faster speeds with no problem !
it is so intermittent and random i am stumped !
any help ?
bo
Re: interrupts
« Reply #1 on: January 24, 2010, 01:50:17 PM »
Increase the debounce interval to  2000 and see if it helps, if so reduce until you get the problem again then increase slightly. You will find that setting on the General Config page, top right hand side.
Offline coop
  •  12 12
    • Signs of Mackinaw
Re: interrupts
« Reply #2 on: January 24, 2010, 02:09:14 PM »
thanks,
i am cutting as we speak, but will try it asap
it will be somewhat hard to tell if it helps right away, since it is intermittent !
i do have one other prob, i will post soon
thanks again,
bo
