Hello Guest it is October 10, 2026, 04:05:22 AM
Author Topic: speed mismatch  (Read 22972 times)
speed mismatch
« on: January 23, 2010, 08:16:18 PM »
On this new mach3 setup seems axis actual speed is only 75% of programmed speed. I must have parameter not properly set. For example, programmed f4 actually moves only at 3 inches/minute. What am I doing wrong?
Jim
Re: speed mismatch
« Reply #1 on: January 23, 2010, 08:19:42 PM »
Does the velocity DRO say 3ipm?
Re: speed mismatch
« Reply #2 on: January 23, 2010, 09:14:49 PM »
yes. example midi g1 x1 f10. result, fro 10, units/min 7.5
Re: speed mismatch
« Reply #3 on: January 24, 2010, 02:31:21 AM »
You may have the FRO % set to 75%, make sure its at 100%
Re: speed mismatch
« Reply #4 on: January 24, 2010, 08:16:04 AM »
Regarding the FRO, I wish it was that simple.
Re: speed mismatch
« Reply #5 on: January 24, 2010, 08:18:42 AM »
please attach your xml  and I will see if I can replicate.
Re: speed mismatch
« Reply #6 on: January 24, 2010, 08:20:10 AM »
I've been running mach since its inseption, back when mach 1 was king, so I pretty much know my way around around the major settings. The Mach 3 program I updated I've been running since maybe 2007.
Re: speed mismatch
« Reply #7 on: January 24, 2010, 08:23:51 AM »
So what are you saying? If you dont want to attach your xml that is fine by me but if you are asking for help then I suggest it might be the quickest way to get this resolved.
Re: speed mismatch
« Reply #8 on: January 24, 2010, 08:52:17 AM »
Sorry, the timing of that last post was such that I was creating it during your request. I have to go to the shop for the xml file and its Sunday so it's gonna take me a while. Hey, thanks for the help. While I'm in the shop I'm gonna play with it a little more too.
Re: speed mismatch
« Reply #9 on: January 24, 2010, 08:57:16 AM »
Ok no problem, stuff like that happens and I am doing my tax returns so I am a bit grumpy ;D
