Hello Guest it is November 17, 2026, 02:12:00 AM
Author Topic: All axis zero when tool change complete?  (Read 15806 times)
« on: January 23, 2010, 04:42:13 PM »
What is happening?
I was test running some code and it was running as expected. A friend showed me something on the settings tab and I shut mach 3 down.
I later restarted it and test ran my code. It now operates differently. After a tool change and spindle start, the axis go to zero slowly, one at a time.
What did we do to change this behavior?
Thanks in advance.
Re: All axis zero when tool change complete?
« Reply #1 on: January 23, 2010, 05:02:40 PM »
Do you just do a manual tool change? If so maybe you turned on the auto toolchange option on General Config page.
« Reply #2 on: January 23, 2010, 05:19:27 PM »
I have it set to Ignore Tool Change to test run the code -- disconnected from a system.
To clarify: X axis slowly goes to zero, then Y, then Z. Only one axis moves at a time.
« Reply #3 on: January 23, 2010, 05:26:52 PM »
attach your xml and a piece of code that gives you the problem and I will try and replicate it.
« Reply #4 on: January 23, 2010, 06:07:01 PM »
If I remove the M3 word, all works normally.
Why would M3 (Spindle Direction) cause the axis to zero?
I am new to MACH. What do you mean when you say xml? The Mach3mill.xml file?
« Reply #5 on: January 23, 2010, 06:39:12 PM »
yes the Mach3Mil.xml  is correct if you are using the standard mill profile.
Not sure why M3 would do that unless your M3 macro has changed somehow. Do a test and just M3 from the MDI line.
« Reply #6 on: January 23, 2010, 08:21:23 PM »
M3 from the MDI causes a zero.
I looked at the m3 macro. it got stepped on...somehow has:
X = PARAM1()
Y = PARAM2()
Z = PARAM3()
CODE "G1 X"&
CODE "Y"&-Y
CODE "Z"&Z
No clue how it got changed.
Looked at m4, it reads : DoSpinCCW()
Assumed m3 should read: DoSpinCW()
Testing...
« Reply #7 on: January 24, 2010, 02:28:46 AM »
Yes, looks like you or someone changed your M3 by accident, the DoSpinCW() is what it should be for a standard setup.
