Hello Guest it is November 13, 2026, 07:22:44 PM
Author Topic: dxf file import question  (Read 24544 times)
mig29
« on: September 21, 2006, 02:38:07 PM »
How do you import a dxf file, convert it to gcode, and assign depths to it?
When I import a dxf file, I get a window that I don't really know what to do with exept hit the convert to gcode button. What are layers? I am just trying ti mill some simple rectangular pockets. I would use the conversational wizard, but my Mach3 did not come with them.
Mike P
Re: dxf file import question
« Reply #1 on: September 21, 2006, 03:37:56 PM »
The conversational wizards are licensed seperately by New Fangled Solutions.
 Have you tried importing the DXF with LazyCAM?
mig29
« Reply #2 on: September 21, 2006, 03:40:49 PM »
I use turbocad to design the things to be milled. I import it into mach3 as a dxf file. After that I don't really know what to do. Is there a tutorial for mach3 that teaches how to assign depths etc..?
« Reply #3 on: September 21, 2006, 03:44:31 PM »
Are you using LazyCAM (its in Mach3) to import? I dint use LazyCAM but I had a look in the beginning and it looked good and has come a long way since. There should be a video on the downloads page showing the basics of LazyCAM.
You can access LazyCAM from the File menu in Mach3.
mig29
« Reply #4 on: September 21, 2006, 03:48:15 PM »
I didn't know it existed. I am using a library computer that can't seem to access that particular tutorial. All of the other ones work fine. I don't have internet on my computer. Do I open the lazy cam window, then import dxf? Or do I import dxf, the open lazycam?
Mike P
« Reply #5 on: September 21, 2006, 03:53:44 PM »
You open lazyCAM then along the top of the screen you will see a button to import CAD files, click on that and browse to your file and import it. I cant be much more help as I have not used LazyCAM but you may be able to work it out easily. Try and get the video downloaded sometime as it should show you the basics. This is a direct link to the video, that might help you get it http://www.machsupport.com/LazyCam/LazyCam.swf
Offline Greolt
  •  956 956
« Reply #6 on: September 21, 2006, 05:28:50 PM »
Can I jump in here with a question?
I bought the New Fangled licence and am happy I did but aren't the rest of the individual wizards included with Mach?
Example: Pocket Cutting, CircularBolt Pattern, Circular Pocket, Cut Arc, etc
« Reply #7 on: September 21, 2006, 05:31:22 PM »
Yes all the individual wizards are free, just the conversational from New Fangled Solutions that you pay a small extra for.
Offline Greolt
  •  956 956
« Reply #8 on: September 21, 2006, 06:21:25 PM »
And well worth it too :)
So getting back to Mig29's question, shouldn't he have the wizards. Can't he use the Rectangular Pocketing wizard?
« Reply #9 on: September 22, 2006, 01:11:03 AM »
Yes he could, also if its a bit more complex than a single pocket he could create the code from one wizard, then another and cut and paste them all together to make up a complete program. When things get a bit more complex LazyCAM might be easier though.
