Hello Guest it is September 29, 2026, 08:43:25 PM
Author Topic: Charge pump is it that simpel ????  (Read 10711 times)
« on: January 18, 2010, 04:10:17 PM »
Can some one tell me if I'm right here.  If I'm in ports and pins / outputs and if i set charge pump port 1 and pin 1 that's it charge pump is working.
Then i can remove the jumper from my bob so when i start the PC the vdf want fire up and once mach is up and running i can move my motors.
I'm asking as it just seems to simple there in no LED on in my diagnostic screen ?
Re: Charge pump is it that simpel ????
« Reply #1 on: January 18, 2010, 04:21:20 PM »
If your BOB supports the chargepump and if that pin is pin 1 on the BOB.
« Reply #2 on: January 18, 2010, 04:25:40 PM »
Your a good man hood all ways there to help
I was just not that use to things being that easy
It makes a nice change
« Reply #3 on: January 18, 2010, 04:29:39 PM »
LOL, on my BOB I think its pin 17 but I never used the chargepump anyway so not 100% sure
