Hello
Guest
it is
November 13, 2026, 10:48:36 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
encoders
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: encoders (Read 11942 times)
boblee
49
encoders
on:
September 20, 2006, 09:26:45 PM »
Hi can anyone tell me if a 100 count encoder could be used with a 200 step motor in Mach3 ?
Is there anyway to correlate the encoder count to the step pulses or step output?
Is there a scaling setting in Mach3 for this?
Thanks Bob
Brian Barker
3,860
Re: encoders
Reply #1 on:
September 20, 2006, 09:33:11 PM »
That should work fine
There are a few people that are doing this and I think that is about the encoder count that they are running...
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
boblee
49
Re: encoders
Reply #2 on:
September 20, 2006, 09:57:14 PM »
Hi Brian thanks for replying so if I were running my steppers in half step 400 steps/rev would I set the ( counts/unit ) setting under the encoder/mpg tab in the ports&pins config dialog to 4 counts/unit?
Bob
bidel167
1
Re: encoders
Reply #3 on:
October 25, 2013, 11:42:17 AM »
Hi can anyone tell me how i can use external encoder and replace DRO of for example x axis i want use motor that is not servo motor
Print
Pages:
1
Go Up
« previous
next »
