Hello Guest it is November 13, 2026, 10:38:03 AM
Author Topic: encoders  (Read 11940 times)
encoders
« on: September 20, 2006, 09:26:45 PM »
Hi can anyone tell me if a 100 count encoder  could be used with a 200 step motor in Mach3 ?
 Is there anyway to correlate the encoder count to the step pulses or step output?
Is there a scaling setting in Mach3 for this?
  Thanks Bob
Re: encoders
« Reply #1 on: September 20, 2006, 09:33:11 PM »
That should work fine :)
There are a few people that are doing this and I think that is about the encoder count that they are running...
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: encoders
« Reply #2 on: September 20, 2006, 09:57:14 PM »
Hi Brian thanks for replying  so if I were running my steppers in half step 400 steps/rev would I set the ( counts/unit ) setting under the encoder/mpg tab in the ports&pins config dialog to 4 counts/unit?
Bob
Re: encoders
« Reply #3 on: October 25, 2013, 11:42:17 AM »
Hi can anyone tell me how i can use external encoder and replace DRO of for example x axis i want use motor that is not servo motor
