Hello Guest it is October 25, 2026, 04:02:11 AM
Author Topic: Zenbot precision  (Read 14119 times)
Offline BUG
  •  15 15
Zenbot precision
« on: January 11, 2010, 09:55:00 AM »
Once you have adjusted my Zenbot.
What precision can I get fiberglass milling 1.5 mm with a 1mm drill?
You can make the 0.05mm
thanks
Re: Zenbot precision
« Reply #1 on: January 11, 2010, 10:33:57 AM »
Not sure what you are asking?
Do you want to know how accurately you can move to and drill a hole or mill something
with your Zenbot?
Offline BUG
  •  15 15
« Reply #2 on: January 11, 2010, 11:19:39 AM »
That offers a precision CNC milling Zenbot fiberglass?
« Reply #3 on: January 11, 2010, 12:41:42 PM »
Sorry, still don't understand.  ???
Offline BUG
  •  15 15
« Reply #4 on: January 20, 2010, 03:08:24 PM »
Hola:
SPANISH
La pregunta es la CNC ZENBOT que precision/desviacion tiene real? Por ejemplo al fresar un cuadrado de 4X4 inches cuanto puede variar.
ENGLISH
The question is the CNC ZENBOT what this your precision/deviation is reality? For example the milling a square of 4x4 inches terms vary.
Thank you. Excuse my english
« Reply #5 on: January 21, 2010, 08:20:33 AM »
I have a Zenbot and it is accurate consistently up to .004 for my woodworking projects. If you are experiencing problems, there are many factors that could apply. The machine itself is belt driven, so expect it not to be as accurate as a mill with ballscrews. The spindle motor is not pro quality, since it is a standard roto-zip which will have unusually high runout. If your motor tuning configs are right, and gen configs are right, it is a very stable, and consistent little machine. How much is your machine deviating? If we are talking thousandths, how many. If we are talking in tens of thousandths, then your motor tunings are probably off.
Offline BUG
  •  15 15
« Reply #6 on: February 12, 2010, 12:02:26 PM »
If I've managed to adjust the machine, the problem came because I interfered the tool wear, small vibrations of the Dremel and adjusting the stepper motor because of adjustments taken so confusing.
Now I get:
Only by moving the axes an accuracy of 0.05 mm (0.002 inch).
In the piece made of fiberglass 0.1 mm (0.04 inch).
Thank you very much everybody.
