Hello Guest it is November 13, 2026, 09:59:53 AM
Author Topic: max nc 10 wave drive  (Read 15188 times)
judah
« on: September 19, 2006, 10:14:23 AM »
Can any one tell me what this is ?
Im useing gecko 210 and get no movement unless this is checked.
is this normal?
also when trying to cal my axise nothing happens already up to 24.000 pulses per unit?
Re: max nc 10 wave drive
« Reply #1 on: September 19, 2006, 06:42:04 PM »
Check your settings and set your ports and pins.. the Port will be port one and the pins is where ever you have it hooked :)
What are you using for a breakout board?
Brian
www.newfangledsolutions.com
www.machsupport.com
judah
« Reply #2 on: September 21, 2006, 10:06:46 AM »
 Iam useing a campbell breakout board. all the ports and pins are set up as they suggest downstream of the break out board
 are 3 gecko 210s running a size 34 stepper each all powered by a 40 volt  7 amp reg power supply.
 say im trying to cut a 2d 1by1 square the machine will move on the rapids put not the cut it self and unless i have max nc10 wave checked nothing will work at all. allso when trying to calb axise it ask for a dis  i enter one and it never moves.
« Reply #3 on: September 21, 2006, 06:27:58 PM »
please post your MXL and I will check your settings
www.machsupport.com
judah
« Reply #4 on: September 24, 2006, 03:42:50 PM »
thanks brian so i shouldnt have to have max nc cheacked?
