Hello Guest it is November 13, 2026, 09:48:29 AM
Author Topic: I have a K2 CNC Need Help Setting up  (Read 10610 times)
Offline NormB
  •  169 169
  • Norm
« on: January 07, 2010, 02:58:42 AM »
I have the tool Hit Indicator and need to understand how to connect this to Mach3.  I know it's nothing less or more than a micro switch in a controlled height block with a spring loaded indicator pad.  Can this be set up as a Probe in Mach3?  Right now it's wired into my controller on Pin 13 so I think it could work like a limit but not to convenient.  any information would be appreciated.
Re: I have a K2 CNC Need Help Setting up
« Reply #1 on: January 07, 2010, 03:29:58 AM »
Yes you will assign it to the Probe input. Do a search for tool height macro or similar as there is loads of info on the macros used.
Offline NormB
  •  169 169
  • Norm
« Reply #2 on: January 07, 2010, 07:05:18 AM »
thank you........I have since done this search and you are right so many it's hard to sort through.  I am working on it though.
