Hello Guest it is November 12, 2026, 11:07:50 PM
Author Topic: Two CNC configurations on one PC, Possible?  (Read 17815 times)
« on: January 02, 2010, 01:45:31 AM »
I have a licensed Mach3 set up and running my 1st machine, It is a simple 3 axis machine using 3 steppers.  I am building a second machine which is a moving gantry with a screw and stepper on each side of the gantry and using 4 steppers.  After my second machine it running and all set up I will take tear down my first machine.
But in the meantime I would like to use the same PC that has mach installed on it to be able to run either of the two machines without having to change all of the configurations and mach set up when I connect up either one of the machines.  Is this possible and if so how would it be done?
Mr. Chips
Retired 3M'r
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Two CNC configurations on one PC, Possible?
« Reply #1 on: January 02, 2010, 02:11:37 AM »
Hi, Mr.Chips
Run Mach3 exe from the installed location, Usually it's located at C:\mach3 folder, You'll see an option to create additional profiles which will allow you to do what you want.
Hope this helps, Chip
« Reply #2 on: January 02, 2010, 02:19:45 AM »
Thanks Chip,
I'll give it a try tomorrow.
Hager
Mr. Chips
Retired 3M'r
« Reply #3 on: January 02, 2010, 06:17:40 AM »
Don't forget also you can clone an existing profile.
Then just change the details that make this different from the first profile
« Reply #4 on: January 02, 2010, 06:53:26 AM »
Phil_H
When you say "Clone" is that just copying the Mach3 icon on the desktop and renaming it. And that is the clone, or are there other steps.
Hager
Mr. Chips
Retired 3M'r
« Reply #5 on: January 02, 2010, 08:19:35 AM »
Hagar
Sorry the Mach3 loader has changed
So you do it like this
You set your machine just the way you like it
You go to the mach3 folder and change that perfect profile which could be the default Mach3_mill.xml
You the copy it to a new name IE "Hager_1"
Then you have two profiles the same
Copy again to "Hager_2"
Now you have three profiles you could keep Mach3_mill.xml as the backup default "A GOOD IDEA"
Then when you run the loader you will see these two extra profiles
You just change what is necessary to make them different to each other
I have a similar setup where one profile is the mill
The second is an engraver
Phil
« Reply #6 on: January 02, 2010, 09:13:14 PM »
You might try reading the Mach installation manual. It has a full explanation of profiles and how and why to create them. See the documentation page on this site for the manual
« Reply #7 on: January 02, 2010, 11:25:55 PM »
No, no, don't do it Ron, not RTFM,  :o noooooooooooooooooooooooooooooooooooooooooooooooo :o
Actually reading the manual is a great idea. :)
As sick as this sounds, when I have some time such as waiting for the machine to finish a part I will read the manual again. Mach3 has so many settings and capabilities that even Art doesn't know them all off of the top of his head and he wrote the program.
 >:D Mike >:D
