Hello Guest it is November 27, 2026, 09:59:12 PM
Poll
Which motor frame would you use (/are using) AND would consider purchasing a cover for? NOTE: Please measure your motor before voting - NEMA23 frame measures ~ 2.25" There are other motors sometimes refered as NEMA23, but actually having a 60mm squ
NEMA 17 square
4 (4.1%)
NEMA 17 square with encoder
1 (1%)
NEMA 23 square (~2.25" or 57mm square)
28 (28.6%)
NEMA 23 square (~2.25" or 57mm square) with encoder
5 (5.1%)
NEMA 34 square
28 (28.6%)
NEMA 34 square with encoder
9 (9.2%)
NEMA 42 square
3 (3.1%)
NEMA 42 square with encoder
0 (0%)
NEMA 23 round
5 (5.1%)
NEMA 23 round with encoder
0 (0%)
NEMA 34 round
1 (1%)
NEMA 34 round with encoder
3 (3.1%)
60mm square frame
10 (10.2%)
60mm square with encoder
1 (1%)
Total Members Voted: 67
Author Topic: Most Popular Motor Frames  (Read 341414 times)
« on: January 01, 2010, 01:47:01 AM »
Hi all,
This poll is related to the product shown in this thread http://www.machsupport.com/forum/index.php/topic,13579.0.html
Comments are welcome.
Daniel
Re: Most Popular Motor Frames
« Reply #1 on: January 15, 2010, 01:05:15 AM »
I can't change my vote, but I should have selected Nema23 Square and 60mm Square.  Keling motors are 60mm - http://www.kelinginc.net/KL23H286-20-8B.pdf
« Reply #2 on: January 15, 2010, 01:33:41 PM »
Dan,
There is an option to allow viewer to change  a vote......if you choose to check the box.
If you can no longer edit the poll, it can be done by admin.
Russ
« Reply #3 on: January 15, 2010, 01:38:05 PM »
Russ,
Don't see this option when I click the Edit Poll option...
I tried to add a note above, but ran out of space - it there anything can be done?
Daniel
« Reply #4 on: January 15, 2010, 01:39:15 PM »
OK Dan, I checked this box for you,
Russ
« Reply #5 on: January 15, 2010, 01:41:55 PM »
Thanks Russ!!
Any way more characters can be added to the question field above, so I complete the note?
Daniel
« Last Edit: January 15, 2010, 01:44:40 PM by Dan13 »
« Reply #6 on: January 15, 2010, 01:48:40 PM »
Dosent look like it. Not sure. Make it smaller or we can put your note in your first post below the poll. I did not know there was a limit in the poll itself.
« Reply #7 on: January 15, 2010, 01:56:17 PM »
OK, made it a bit shorter, but still need 3 more characters. But the message is understandable as it is now, I think.
Daniel
« Reply #8 on: January 15, 2010, 02:02:09 PM »
I think so too.
Might just check into that, see if it can easily be expanded a bit.
« Reply #9 on: January 15, 2010, 04:14:09 PM »
I got my votes corrected, Thanks.
btw Daniel, just drop the word "please", OR say
". . . . - NEMA23 frames measure ~ 2.25", but the 60mm frames measure ~ 2.38"
