Hello Guest it is November 27, 2026, 09:23:15 PM
Author Topic: Spindle off  (Read 8037 times)
Spindle off
« on: December 31, 2009, 02:33:53 PM »
Have a spindle off button on my bridgeport. Made a brain using its input (input 31) and terminates to "button press" "spindle off". It works fine but it also turns the spindle on which I don't want. Tried a few variations in the brain commands but on/off is as good as I can achieve.  Is there another way?
Thanks, RonO
Re: Spindle off
« Reply #1 on: January 01, 2010, 05:10:43 PM »
Going to try to do this with a macropump.
Re: Spindle off
« Reply #2 on: January 02, 2010, 04:05:50 PM »
You can use a multiple input lobe and use the spindle on led as a second input to this lobe. This should be an and function lobe.
 When the spindle on LED is off nothing gets out but if the spindle is on, the spindle off button press happens.
Sounds good but I don't have the time to try it out.
Let me know if this works,
Mike
