Hello Guest it is November 13, 2026, 09:47:01 AM
Author Topic: Parallel Port Pin 1 problem  (Read 9657 times)
« on: December 17, 2009, 09:38:23 PM »
I don't know what caused this but pin 1 of the parallel port stopped functioning as my X axis step output.  I tried using pin 1 as the direction output instead to no avail.  Tried using it with the Y and Z axis, but still no success.
Has anyone had this problem before?  I am using all of the output pins, so I can't just change to another pin.  I've tried upgrading to 3.45, without success, and given the port driver causing problems with laptops, I went back to version 2.65.
I know the parallel port output is the problem as I have tested the outputs with a digital probe.  It is not my breakout board.
Thanks in advance for any suggestions.
Ken Klausner
Re: Parallel Port Pin 1 problem
« Reply #1 on: December 18, 2009, 10:28:45 AM »
If you can try a normal type output such as coolant on Pin 1 and see if it works, if not then it would seem your parallel port is bad.
