Hello Guest it is November 13, 2026, 07:59:48 PM
Author Topic: Engraving around outside of a tube  (Read 35913 times)
Offline birdbrain
  •  41 41
  • Stupidity, beyond belief!
« on: December 17, 2009, 09:43:53 AM »
I have a job to do which involves engraving text and logo around the outside of small (20mm) tubes. The engraving would be at a single fixed depth of, say, 0.1mm.
My mill is a K2 clone with a 4th axis (rotational). The rotation is parallel to the Y axis. So, the cutting movements will be on X and A axis( with the plunge on Z axis as usual).
I also have the full version of Lazycam installed. 8)
The logos etc. are graphics files. They can be easily converted between graphics file formats.
How can I do this engraving job without buying additional, expensive software?
Re: Engraving around outside of a tube
« Reply #1 on: December 17, 2009, 10:01:00 AM »
Check out CNCWrapper http://www.cncwrapper.com
Daniel
Offline birdbrain
  •  41 41
« Reply #2 on: December 17, 2009, 12:28:14 PM »
Daniel
Hey Thanks Daniel!
That's just what I've been looking for.
Offline birdbrain
  •  41 41
« Reply #3 on: December 17, 2009, 02:14:35 PM »
Cnc Wrapper will be handy when I have managed to make a G-code file from an image.
Does anyone know of a cheap software that can convert an image file (i.e. a logo) into G-code?
I have lazycam but it seams unable to convert any of my images. The images are Fireworks PNG files (they can also be saved as GIF, TIFF or JPG).
« Reply #4 on: December 17, 2009, 02:25:36 PM »
Try CamBam http://www.cambam.co.uk it has a free version with some limitations... http://www.cambam.co.uk/download/previous/beta-081.html may be it will do for you.
Daniel
« Last Edit: December 17, 2009, 02:27:34 PM by Dan13 »
« Reply #5 on: December 17, 2009, 02:38:16 PM »
Creating g-code from an image file is very inefficient. You might want to convert the image to a vector file first, then convert the vectors to g-code. Could cut your machine time be a factor of 10 or more.
« Reply #6 on: December 17, 2009, 04:43:18 PM »
You might want to check out D2NC (there is a link to it in the DOWNLOADS section).  Not free (think it was $65.00).  I have used it for many engraving projects with great success.
Bob@BobsShop
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #7 on: December 18, 2009, 06:02:47 AM »
There is also this software that converts images to g-code I have not used it so I can not comment on its results :-
http://cgi.ebay.co.uk/picture-to-g-code-cad-cam-cnc-software_W0QQitemZ190359039361QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2c52486d81
Graham
Offline birdbrain
  •  41 41
« Reply #8 on: December 19, 2009, 03:47:38 AM »
This is a very important point.
I have now bought a really good vector drawing program (serif DrawPlus)http://www.freeserifsoftware.com/software/drawplus/index.asp, it only cost 9.99 GBP for the full version!. Drawplus can save files in the DXF format and they are easily converted to G-code by Lazycam.
I also have D2NC installed and it is really good for making quick wizards. D2NC can also convert Drawplus DXF files to tube wrapped G-code.
So, thanks to all for your advice. I have been able to check out some software that I didn't even know existed.
By the way, CamBam looks like a very useful piece of software. I'm definitely going to install it. Only thing is that it'll take some time to learn how to use it.  ::)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #9 on: December 20, 2009, 10:44:55 AM »
why is "special" software needed for wrapping engraving gcode round a cylinder? just swap the Y code to the A code and as long as the steps per are set right - job done. Isn't it?
