Hello Guest it is November 13, 2026, 09:43:25 AM
Author Topic: Motor Home/ Soft Limits  (Read 10396 times)
« on: December 10, 2009, 08:32:37 PM »
Iam very new to cnc Ive just finished inputting some info into mach3 the problem I have is on motor home/soft limits,I put in the size of my table the rev,home neg,auto zero are all checked but when I go back to the main control panel in the window in the upper right hand corner it does not show the table size in either machine coordinates or work off set.
Re: Motor Home/ Soft Limits
« Reply #1 on: December 10, 2009, 09:18:15 PM »
Hi Barry,
   Toggle the DISPLAY MODE button and you should see the white dotted lines illustrating the extents of your Soft Limits.
RC
« Last Edit: December 10, 2009, 09:20:24 PM by Overloaded »
