Hello Guest it is November 13, 2026, 03:12:16 PM
Author Topic: G31 scanning slow z speed?  (Read 12889 times)
« on: December 08, 2009, 02:41:49 PM »
I'm using mach 2 (have mach III too) do digitize with a high speed probe I built.
Anybody know how to get the mach to pick up the speed of the z axis during a G31 op?
Looks like mach really slows down the z axis during a scan, (it's only slow on the way down, z axis runs full bore on the way back up to zero)
Any ideas?
Re: G31 scanning slow z speed?
« Reply #1 on: December 08, 2009, 05:53:31 PM »
Do you have a feedrate command in your probing code?
« Reply #2 on: December 08, 2009, 07:02:40 PM »
I don't but was able to basically add in an F300 one line then a F100 a line or two down with a word processor and that does the trick.
Just wondering if there is a way to tell mach to run the z axis at a given speed during a G 31?
« Last Edit: December 08, 2009, 07:11:30 PM by Tristar500 »
« Reply #3 on: December 08, 2009, 07:15:12 PM »
I noticed a similar issue. The plunge speed on a G31 seems to be OK but the Z acceleration on the plunge move appears to be that of the X and Y axis.   The retract move is normal.  X and Y acccel is set at 8 and z is 30. I didn't notice this until I lowered the X and Y accel. I do have a feedrate command in the G31 line. Probably work on this more tomorrow.
