Hello
Guest
it is
November 13, 2026, 01:51:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Image LED on Mach3Screen.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Image LED on Mach3Screen. (Read 14489 times)
giannis121
145
on:
December 08, 2009, 07:15:24 AM »
When using "screen4", we can use bitmap LEDs by showing the bitmap path to the properties of the LED.
Where is that setting in Mach3Screen? I can't locate it...
Giannis
Joseph
14
Re: Image LED on Mach3Screen.
Reply #1 on:
December 08, 2009, 11:36:59 AM »
I think you can double click on "None" for image path to allow a different bitmap.
giannis121
145
Reply #2 on:
December 09, 2009, 12:59:50 AM »
Very good,
but where is that menu hidden?
Klaus1311
531
Reply #3 on:
December 09, 2009, 04:49:29 AM »
Hi Giannis
are you using Mach3Screen or MachScreen? If you are using MachScreen you find in the property dialog all the parameters for the selected controls.
Klaus
The brain isn't a soap, it doesn't shrink when used.
giannis121
145
Reply #4 on:
December 09, 2009, 04:52:18 AM »
I use Mach3Screen.
Where can i download MachScreen?
I can see it in the download page anywhere....
Klaus1311
531
Reply #5 on:
December 09, 2009, 04:55:46 AM »
Hi Giannis
you can download it from:
http://www.kd-dietz.de
select english move to project -> mach3 screendesigner -> download
giannis121
145
Reply #6 on:
December 09, 2009, 05:03:26 AM »
Wow. look some things...
I use 2 years now Screen4 and Mach3Screen and i didn't know there is MachScreen.
Why there is no link in the main download page?
Looks quite good...
Thanks for replying...
Print
Pages:
1
Go Up
« previous
next »
