Mach Discussion => General Mach Discussion => Topic started by: giannis121 on December 08, 2009, 08:15:24 AM
When using "screen4", we can use bitmap LEDs by showing the bitmap path to the properties of the LED.
Where is that setting in Mach3Screen? I can't locate it...
Giannis
I think you can double click on "None" for image path to allow a different bitmap.
Very good,
but where is that menu hidden? ???
Hi Giannis
are you using Mach3Screen or MachScreen? If you are using MachScreen you find in the property dialog all the parameters for the selected controls.
Klaus
I use Mach3Screen.
Where can i download MachScreen?
I can see it in the download page anywhere.... :(
Hi Giannis
you can download it from:
http://www.kd-dietz.de
select english move to project -> mach3 screendesigner -> download
Wow. look some things...
I use 2 years now Screen4 and Mach3Screen and i didn't know there is MachScreen.
Why there is no link in the main download page?
Looks quite good...
Thanks for replying...
