Hello Guest it is November 21, 2026, 09:03:26 AM
Author Topic: New Questions from Stringkilla  (Read 16671 times)
« on: January 08, 2006, 01:24:55 PM »
Hi guys. Now that I have Mill I have some other questions.
So guys, I watched the video on coordinates and I got that to set up the machine coord's and home coord's I need to have the wired up, correct. So I need help with this wiring diagram. I want to mount a switch at each end of the X and Y axis and one at the top of Z axis. I believe I need to wire the X, and Y switches in series but I'm not sure, since the switches have three lugs. I have four Radio Shack #275-017A switches, rated 125/250 vac. How do I wire them up in series
« Last Edit: January 09, 2006, 01:02:58 PM by stringkilla »
Vmax
Re: Questions from Stringkilla
« Reply #1 on: January 08, 2006, 07:31:28 PM »
String The Estop depends on how you want to use the Estop.
If you only want to alert Mach by using the estop pin, then you only need 1
If you want to alert mach and open a contactor to kill the power input you will need 2 or use one of machs output pins to trip the contactor thru a relay.
« Reply #2 on: January 08, 2006, 07:55:05 PM »
Cool, I have an other project that I am working on and that could fit in!
www.newfangledsolutions.com
www.machsupport.com
