Hello Guest it is November 13, 2026, 10:37:07 AM
Author Topic: Mach3 modify question  (Read 12268 times)
Offline tivoi
  •  29 29
« on: November 25, 2009, 11:05:08 PM »
How mach3 can wait extranal input when mach3 finish one line code?
thanks alote  ???
Re: Mach3 modify question
« Reply #1 on: November 26, 2009, 01:26:30 AM »
Not sure exactly what you are meaning but maybe single block is what you are looking for?
Offline tivoi
  •  29 29
« Reply #2 on: November 26, 2009, 07:53:27 AM »
thanks Hood.
I want mach3 run one line code , and stop , when have signal input, it's run netx line code.
« Reply #3 on: November 26, 2009, 07:58:09 AM »
You can do that with single block, just have an OEM trigger set to imitate the  Start button and every time Mach sees that signal it will do the next line of code.
Offline tivoi
  •  29 29
« Reply #4 on: November 26, 2009, 09:00:08 AM »
thanks Hood alot
