Hello Guest it is November 13, 2026, 09:39:36 AM
Author Topic: Mach3 Z-axis question  (Read 9683 times)
« on: November 25, 2009, 12:17:25 PM »
I'm brand new with Mach3 and a new control box.
When I set Z to the top of the material, I move X & Y off the edge of the material to an inside spot so I can set the Z-axis easier than if I set it on the corner of the material. After I set the Z height, I re-home the machine to the material home position. When I do that, the X & Y axis move first and the Z picks up off the material last. I want the Z-axis to pick up before X & Y go home so the bit isn't running right on top of the materil.
Any suggestions?
Thanks!
Chris
Re: Mach3 Z-axis question
« Reply #1 on: November 25, 2009, 12:52:36 PM »
Either change your G-code, or go to Config->SafeZ Config, and enable SafeZ.
