Hello Guest it is September 12, 2026, 07:19:30 AM
Author Topic: I know I read this  (Read 10652 times)
I know I read this
« on: September 08, 2006, 07:08:36 PM »
I just cant seem to find it. The main display is oversized on my screen and I cant seem to figure out how to format it properly. Sorry i suck so bad. first one with the answers wins.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: I know I read this
« Reply #1 on: September 08, 2006, 08:17:07 PM »
Under "Config"/"General Config/Auto screen enlarge
Should fix the problem
This might be slightly different depending on which version of Mach you’re using. The developer’s edition (which I have cut out hundreds of parts with no problems) has it located here. I might add that I really like the new organized Mach ;D ;D ;D
« Last Edit: September 08, 2006, 08:20:59 PM by zealouse »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: September 08, 2006, 08:21:20 PM »
Hi, guynamedbathgate
May be Config, General Logic,  bottom center, Auto Screen Enlarge, un check it, OK, then restart Mach.
Or is this a Windows screen problem,. Start, Control Panel, Display, Settings, screen resoluation, move bar, Apply, OK.
Second again ------------------so sad
Hope this Helps, Chip
