Hello Guest it is November 12, 2026, 08:46:50 AM
Author Topic: Smoothstepper config problems with known, good Parallel Port XML  (Read 13474 times)
Offline Bfive
  •  13 13
« on: November 10, 2009, 03:30:16 AM »
Hi all,
This forum seems pretty quiet...
I've been trying to set up my Smoothstepper. My software is all up to date. I'm using Mach3 R3.042.032 (released Nov9), smoothstepper USBDriver2.04.16.zip and Plug-in Beta2_v015ogx2.m3p (released Nov7). I have a good XML file that works perfectly with the parallel port. However, when I try the same XML with Smoothstepper, my X and Z drives to not enable while my Y drive enables but does not move. Any idea where to start with the troubleshooting?
Thanks!
« Last Edit: November 10, 2009, 03:44:44 AM by Bfive »
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Smoothstepper config problems with known, good Parallel Port XML
« Reply #1 on: November 10, 2009, 08:04:11 AM »
Did you tell Mach to use the SS as your motion control device??? I would guess not. You have to go into Function Cfgs->Reset Dev Sel.. and then restart Mach. Now when you start back up you'll get the license terms screen and then the 'Hey I found an external motion device' dialog. Select the SmoothStepper from the list.
Happy machining , Jeff Birt
« Reply #2 on: March 24, 2010, 09:23:45 PM »
Sorry wrong post
