Hello
Guest
it is
October 24, 2026, 04:58:35 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Power Supply upgrade 24-48 G540 the Bad Pins?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Power Supply upgrade 24-48 G540 the Bad Pins? (Read 25831 times)
Carnoustie, Scotland
Re: Power Supply upgrade 24-48 G540 the Bad Pins?
Reply #10 on:
November 08, 2009, 03:58:53 AM »
Ah ok, thought that might be the case, you would still however be able to monitor in Parmon I would think if you toggled by shorting them to a ground pin.
Tweakie.CNC
9,374
Super Kitty
Reply #11 on:
November 08, 2009, 04:32:42 AM »
Yes - that is the way to test the input pin functions - thanks Hood.
JigSaw
13
Reply #12 on:
November 09, 2009, 04:02:09 AM »
Ok Cool what pin is ground ?
I am running at the moment all good but still would like to get to the bottom of this.
Can the optos be easily replace on the G540 probably should go and ask on the Gecko forum but before I do that I thought I would just ask
Thanks Willy
Tweakie.CNC
9,374
Super Kitty
Reply #13 on:
November 09, 2009, 05:17:17 AM »
Pins 18 to 25 inc. are all ground.
Print
Pages:
1
2
Go Up
« previous
next »
