Hello Guest it is October 24, 2026, 04:10:47 AM
Author Topic: Power Supply upgrade 24-48 G540 the Bad Pins?  (Read 25827 times)
Re: Power Supply upgrade 24-48 G540 the Bad Pins?
« Reply #10 on: November 08, 2009, 03:58:53 AM »
Ah ok, thought that might be the case, you would still however be able to monitor in Parmon I would think if you toggled by shorting them to a ground pin.
  •  9,374 9,374
« Reply #11 on: November 08, 2009, 04:32:42 AM »
Yes - that is the way to test the input pin functions - thanks Hood.
« Reply #12 on: November 09, 2009, 04:02:09 AM »
Ok Cool what pin is ground ?
I am running at the moment all good but still would like to get to the bottom of this.
Can the optos be easily replace on the G540 probably should go and ask on the Gecko forum but before I do that I thought I would just ask  :)
Thanks Willy
  •  9,374 9,374
« Reply #13 on: November 09, 2009, 05:17:17 AM »
Pins 18 to 25 inc. are all ground.
