Hello Guest it is October 21, 2026, 07:13:18 PM
Author Topic: Nested comments?  (Read 13822 times)
Offline Fastest1
  •  920 920
  • Houston, TX
Nested comments?
« on: November 01, 2009, 04:09:35 PM »
I drew a part on bobcad, assigned and verified the tool path there and all looked correct. Then when I try to run it on Mach it stops and says "Nested comment found line 9". Isnt line 9 specified as N09? If so all I can see that it says is "N09 Z.1. I cant seem to get it to run from any line. Trying to simulate it on the screen before I turn on the controller.
Re: Nested comments?
« Reply #1 on: November 01, 2009, 04:19:15 PM »
Line nine will be the ninth line down which is probably not the N09.
What that will mean is there are 2 or more comments on the same line.
Post your code and it should be easy enough found.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #2 on: November 01, 2009, 04:49:24 PM »
Will you point it out?
« Reply #3 on: November 01, 2009, 04:52:36 PM »
(PROGRAM NAME - SHERLINE WAY COVER FRONT PLATE (SLIDING).NC)
Has a comment within a comment (nested)
Will work fine if you remove the () round the sliding
(PROGRAM NAME - SHERLINE WAY COVER FRONT PLATE SLIDING.NC)
« Last Edit: November 01, 2009, 04:55:16 PM by Hood »
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #4 on: November 01, 2009, 05:06:45 PM »
Hood you are the man! Thank you
« Reply #5 on: November 01, 2009, 05:08:34 PM »
np
